Sapphire park kill pattern.
dudek_peter
21
Soooo here’s the deal I have a 2013 duo liberty WC. I set up my event in command written as: When slide switch 3 is on and input 1 (that’s my park wire) is on do x pattern. That works just fine but when I am in park and in slide switch 3 the take downs don’t work, alleys don’t work and the traffic advisor on the back of the bar doesn’t work. When I’m in SS3 in drive everything works fine. Same as SS1 and SS2 when I’m in park or drive it works. It seems when ever it’s in SS3 none of the other bar functions work.
NoLimitSquads
339
Minnesota
It kinda sounds like an issue with your priorities. Takedowns, Alleys, and TA should be higher than your Slide Three and Park Input.
dudek_peter
21
Also, is there a reason why you are using input 1 for park? Sapphire has default programming for input 3 to be your Park Kill.
So it isn’t a fresh brand new build. It’s my friends EMS fly car and input 3 is tied into the howler. And I’m still kinda newish at command, how do I set my priorities?
NoLimitSquads
339
Minnesota
Click on the tab that has the arrows going up and down. There will be a list of inputs and functions, get them arranged in the right order, and everything should work how you want it to.
Reactions: dudek_peter
NoLimitSquads
339
Minnesota
And another noob question, does it matter that I didn’t use the built in park kill wire?
Ive never not used it, so I can’t quite answer that question. Depending on what you are doing, it probably isn’t necessary. But there are definitely some things built into the programming that make it easier if you use the dedicated park kill wire. Can you swap the two inputs, and use the input 1 for the howler, and switch your park wire to the input 3(white/orange)?
dudek_peter
21
Next time I’m there I’ll take a peek at it
htamboli
