SS2000SM reset
paff2
842
Lancaster, PA
how do I reset all programmed buttons to off on start up?
I bought a used unit and the gun lock and spotlight buttons are always powered on every time the unit starts up. Can I reset it without a mic?
paff2
842
Lancaster, PA
I tried following those steps to no avail. How can I tell if it has been disabled?
buddek09
339
US, Ohio
Power the unit up, unplug the control head, while holding down the standby button plug the control head back in, release the button. The first 5 buttons should light up in the center of the controller, if they don't then it's locked out and you will need a mic to enter programming. If you do get into programming hit the button for Level 3, then deselect the gun lock and spotlight buttons, and then hit the standby button twice. This should turn off those two buttons and save the configuration and exit programming.
airflores
