Switches & Controllers
Jman423
Sep 10, 2010
3,391
United States
Don't I just need one or two toggle switches on my dashboard to turn my stuff on? What are all of these other controllers and switch boxes for?
Discuss!
Please keep it clean and organized, this forum section is heavily moderated to keep information organized. We're going to use content from these discussions to compile a helpful guide for users seeking information about products in this industry.
Carlos SpicyWeiner
May 3, 2012
5,233
Lakeland, Florida
Need to know how many amps each module draws and what amperage each switch is rated for.
May 9, 2012
1,153
Central Florida
I use one 16A rocker switch for my lights - It powers the following -
Feniex Pegasus - I'm assuming 5 amps
2 Cannons - .5 amps each so 1 amp total
8 Feniex T-6s at 1 amp so 8 amps
1 Cobra 600 at 3 amps
So I'm in the ball park of being maxed out for one switch. I have the switch fused at the battery with a 15 amp fuse so if it overloads or something goes wrong it will just kill everything.
My numbers may not be accurate with the amp ratings, but just what I figure them to be. FEVER probably knows the exact amp draw of each product.
philyumpshus
1,281
Malone, NY
Anyone ever use a rotary switch hooked to relays for lighting control? It could function like a slide switch but I think it would be more robust that your average slider. Unitrol sells the Omega 90 siren amp with an "undercover" controller called the U3500. You can control your lights and siren from a single rotary switch. Pretty neat!
ErikH
