Sync Grill lights with lightbar
todd022
2
Charleston, SC
I have two nForce (part# ENFDGS1(XX) ) grille lights mounted in the grille. I have an overhead nForce (part# ENFLB) lightbar. Everything is run to the trunk: lightbar to breakout box and the grille lights/tail light flasher module are run to the nEnergy 400 remote siren control unit.
My question is: Can I connect my grille lights to the breakout box or elsewhere to make them sync with my lightbar takedowns? Ideally, the grille lights would mimic whatever my takedowns do (flash when in emergency mode, steady bright for scene lighting/takedown, etc). I have the green wire from the grille lights connected to the siren control unit currently.
Thank you for your help!
EVT
622
Midwest
The grille lights cannot be connected/controlled via the breakout box. You should be able to connect the red/white wire to the TD output on your nERGY siren controller to have them come on with the TD of the lightbar.
The red/white wire will override the red wire, but as the lightbar takedowns will over ride the flashing mode.
The green wire is sync and should not be connected to the nERGY. The green wires from both grille lights should be connected to each other for sync.
airflores
