Statie458
Hi folks, I have a bit of a tech question that I hope someone could provide some insight. But just to give everyone an idea of what I'm running:
1, First and foremost all equipment I have installed is made by Whelen.
2, I Have a HHS2200 that powers two ULF44. (Let call them A: for the front and B: for the rear)
A, powers all the front lights which consist of 6 Microns.
B, The second ULF44 powers all the rear equipment, that consists of six Ions in the rear deck. Eight vertex's (vertexi?) in the rear trunk lid and rear corner lights. And, finely two microns by the rear license plate.
Every light head was set to steady burn before installation with the idea I could change flash patterns with the remote. So on the remote I have Back, Front and All. I programed the HHS2200 to have three of the outlets set to momentary on/off. I then fed those outlets via a splice to both of the ULF44's input terminals to control Low Power, Pattern Override, and Scan-Lock™ features. I then wired the two ULF44 Sync terminals to each other.
So the question I have is would there be anything beneficial by connecting every individuals light heads Grey SYNC wire together and then to their respective ULF44 controller, the way I have the car wired up now works well but I was wondering if could I get more out of the equipment I have?
I'm a novists on this stuff at best so any input would be greatly appreciated!
Thanks again.
~Mike
Thanks again.
~Mike
