For Sale [USED][BLUE] Whelen Vertex™ Super-LED® Hide-a-way
NJ_EMT
99
New Jersey
For sale I have two, Whelen Vertex LED's in solid blue. Both units have been previously installed and remain fully operational and in good condition aside from regular wear and tear and some left over silicone residue. Both lights have been separated from the in-line flasher however I can re-attach the the wire harness prior to shipment if requested. Both wire harnesses have approximately 2 feet of wire length still left.
Asking $89.99 for both + FREE SHIPPING.
NOTE: Does not come with mounting screws or rubber gaskets.
FROM THE MANUFACTURER:
FEATURES
  • Ultra small, self-contained, hemispheric LED light, for surface mount or internal mount within composite head lamps, cornering lamps and taillight assemblies.
  • 25 Scan-LockTM flash patterns,includes synchronize feature for alternating and synchronous flashing of multiple lamps.
  • New lens technology enhances light distribution for optimum dispersion and intensity of the warning signal at critical angles.
  • Includes pre wired and sealed 9' neoprene cable to the light head and lamp driver, with 4-22 gauge power, pattern and synchronize pigtail wires.
  • Aluminum base and advanced thermal heat management system is designed for endless years of trouble free service
  • Lamp and in-line lamp driver are fully encapsulated for moisture and vibration resistance.
  • Omni-directional light head mounts in any position (orientation), vertically or horizontally.
  • Available in red, amber, white and blue. LED color must match color of the lens it is installed behind, except for clear lens.
  • 10 - 16 VDC.
  • SAE Class 5.
  • No RFI noise emitted.
  • Two screws hold the lamp securely in place.
  • 1" hole makes this LED module backwards compatible to HA238 and standard 1" Hide-A-Way style lamps.
  • Simple installation with no separate lamp drivers, flashers, ballast or power supplies to install
ErikH
