cajunblitz
Up for sale is the Whelen Cemcom Series CARBIDE 200 Watt Siren & Switcher, Model CCSRNT4G
This item is New in the Box.
Type: Siren, Self Contained with Lighting Switches
Color: N/A
Qty. 2 Available
Payment: PayPal, Contact me for payment details!
MSRP: $1,849.00 each
PRICE: $849.00 Includes USPS Priority Flat Rate Shipping
NOTE: Example shows Auxiliary Siren Amp. This offer DOES NOT include the Auxiliary Siren Amp.
- 3 Section Control Head with 21 Push Buttons and 4-Position Slide Switch
- Fully Supports all WeCan Series products including SOLO, DUO, and TRIO WeCan lightbars
- Control warning lights, siren, and Traffic Advisor functions from a single keypad
- Windows based software allows for easy program configuration via USB 2.0
- 16 Expansion Inputs (8 positive and 8 negative switched)
- Supports up to 2 of the following: front WeCan Inner Edge, new rear WeCan Inner Edge, or optional remote 16 output modules
- Separate back-light control
- 18 fully protected and fused outputs
- 200 Watt Siren supports one or two 100 watt speakers
- LED indicator lights allow for simple troubleshooting of outputs and WeCan network
- Easily accessible fuses and connections
- Heavy-duty power and output connectors
- Supports WeCan dual siren amplifier option
- Standard 9C Traffic Advisor driver and connector
- New heavy-duty crimp style connections on WeCan port
- Configurable Load Manager
- Configurable Ignition Delay Timer
- Expanded support for Photocell
- Full set of siren tones
- Supports new WeCan dual siren amplifier option
- 18 Outputs: 2 x 20A (steady or flashing), 7 x 10A (steady or flashing), 1 x 10A Isolated Dry Contact Relay (steady only), 8 x 1A (steady or flashing)
- 4 Programmable Logic Inputs
- Input Voltage 12.8 VDC ±20% (Negative Ground Only)
- Main Input Current 80 Amps Max.
- Main Siren Fuse 20 Amps
- Stand-by Current (back-light off) Ign.On - 80mA (typ) / Ign.Off - 100 uA (typ)
- Operating Temperature -30°C to +60°C
- Storage Temperature -40°C to +70°C
- Humidity 99% (Non-condensing)
- Output Load Two, 11 Ohm Speakers
- Output Power Two, 100 Watt Speakers
Color: N/A
Qty. 2 Available
