Whelen Inner Edge Install Help
Nov 24, 2016
29
Mahopac
Hello all,
I currently have an installing an Inner Edge that's made for a 2006 Impala. The take downs aren't working while connected to the power supply and there's nothing in the manual for what the white wire is. Any help would be appreciated. The model is IM06UFZ
Nolines
1,681
Margate, FL
Really? Says apply 12 volts to the white/black wire for the takedowns and fuse at 1 amp. I'll upload it in a few ... Driving
Nolines
1,681
Margate, FL
Here you go, but wait there's more... White/green scan lock.. white/orange steady burn..
  • 14060.pdf
Nolines
1,681
Margate, FL
Is this a split design?? Tried searching based on IM06UFZ and it pulled up mostly split versions can you give more info, pictures?
Nolines
1,681
Margate, FL
Maybe this... It says white is a scan lock wire, 4 wires.. red BLK green and white...
  • 14043.pdf
Hmood
