I took the Mini Justice from my wrecked Fit, ordered the inner sections and aluminum bar from Whelen, and made an "short" version. I'll post a video later.
It's actually fairly simple to do. The justice bottom domes are held in with screws and retainer clips. Take out the clips and you can slide the bottom domes off, then pop out the clips. This allows you to simply set the dome back on top of the bar, no sliding required!
Cut it down to size and extended the wire harness to make the connections on the far side.
I allocated the four CON3 modules to the rear, since that's where I typically need the warning power.
Still trying to figure out a way to mount it. Looking at getting a strap kit.
But for kicks, I added some magnets to an old strap foot.
