Wiring it right. Info on wiring, connections, splices etc..
JohnMarcson
May 7, 2010
10,989
Northwest Ohio
This thread will be for info and pics on how to properly wire various things. Example, a write up on how to solder and heat shrink connections.
EMT-BLS
2,640
Waterbury, CT
It's still a "how-to properly install" question. When mounting amps/lights, do you first mount the light/amp, and then run the wiring? Or do you run the wires, and then mount the light/amp?
hitman38367
881
West Tennessee, USA
I always mount the light or amp then run wires. This way allows me to attach the wire to the light/amp and then run the wire along the path I prefer to wherever the ending point is. I don't waste wire this way. Example. I install a grille light or grille lights. Once I have everything where I want it, I then put my spool rack at the front of the vehicle and pull wires to where I want them to end and I retrace the wire path securing it as I work my way back to the grille area. When I get back to the grille area, I then pull the wire to the intended light and snip it. I find that I save more wire by doing this. Everyone is going to have their own method. This is just the one that works for me.
OCD Mobile
105
Queens NY
always run wires first. much neater when you actually mount the light/amp/speaker etc
factorone33
492
Merriam, KS
I have a loose "routine" for doing installation work:
1. "Lay out" the vehicle; get an idea of where everything is going to be mounted to help with logistics;
2. Get all the wiring/supplies you'll need. It's easier to run one long piece of wire than to splice it six times and add resistance across the board;
3. Mount all your equipment, lights, boxes, speakers, trunk trays, consoles, etc: this does not include things like partitions or transport seats that could make it more difficult to run wiring or mount other equipment;
4. Run all your wiring, cables, harnesses, and whatnot to the equipment requiring it, and make your connections at the load/receiving end (i.e. hook lights up to wires at the light-side of the circuit);
5. Mount partitions, transport seats, gun racks, and anything else left over;
6. Finish making connections and complete the wiring.
Some people run the wiring first, and mount second, but I have always found it infinitely easier to mount first, and deal with wiring second, as running wiring first may end up limiting how (or where) you mount your equipment.
Reactions: 94yj and dawson75
Torpedo
583
USA Fl
Another user posted this earlier, looks to be good info especially for old school amp draws.
Via Google images and ELB user C2 installs. Nice. Thanks!
Torpedo
583
USA Fl
I am nowhere near vested enough in this community to post this so here I go anyways...
Shouldn't a rouge moderator know better than to post a question or ask an opinion in this thread?
"Also, this section is for sharing "Tips & Tricks", please don't request help or opinions in this forum"
OOps, did I just ask a question? Oh $*!+
As always, respect!
:hail:
PS, It would be fine by me to disallow this post. Just pointing out the humor.
Torpedo
583
USA Fl
Wires first whenever possible. This way I can't help but leave a serviceable and/or drip loop at each device.
chief1562
5,840
Slaterville/NY
Mount everything first then run wires.
Done it that way from the beginning will do it until the end.
Reactions: fire9508
EMT-BLS
2,640
Waterbury, CT
Two notes.
First, I am not a moderator...My role is mostly site related issues, off site.
Second, I meant it for future users to see. I can just ask one of the guys in chat, but I'm trying to build the thread with actual how-to's. If you'll look at the reply from factorone33, you'll see that now a newb can come along and see that, instead of having to make a whole new thread/get it wrong.
Ocean17
4
Illinois
I couldn't help but note one member mentioning soldering connections. I am a member of the ABYC (American Boat and Yacht Council) as a certified marine electrical technician. Over the years, I have come to treat emergency vehicles as I would a boat or marine environment. A fact that I was shocked to learn back when, was that they suggest never soldering wiring in something that moves like a vehicle or boat. Their position is that soldering turns the stranded wiring into a solid wire and where the solder ends becomes a weak point subject to vibration and breaking. Therefore I now crimp all my mobile connections, with the proper crimp terminals and calibrated crimp tool.
It makes sense after you think about it for a while, you wouldn't wire a car or boat with solid wire instead of stranded.... I came from an electronics background and we soldered everything, so it was a bit of eating humble pie and learning a better way, but now I crimp, no solder.
Thanks,
Ocean17
911signalusa
41
USA Florida
To help installers install emergency lights quickly and easily, we have created a whole series of how-to-videos on our YouTube page. In this video, Mike, our installation expert, is installing police lights to the front bumper of our Dodge Charger demo vehicle. In addition to the video, a detailed description is listed below the video.
Let us know if you have any questions. Thanks and have a good day.
Rhinojoe
83
Exempt
Thanks,
Ocean17
+1
Also use a proper set of crimping pliers, such as Stake-On pliers, and know that there's a seam in the crimp connection and position the crimping pliers male tip OPPOSITE of the crimp connector's seam for a correct/positive crimp. I also used marine quality connectors, with heat shrink ends such as made by NOBLE then use black heatshrink, (if exterior mount).
Made in USA Noble Wire & Terminal Corp. - The Complete Wholesale Line of* Terminals, Wire and Wiring Devices,* Nationwide
RJ
Torpedo
583
USA Fl
EMT-BLS said:
Two notes.
:duh:
DOH !
JazzDad
5,165
USA
1. "Lay out" the vehicle; get an idea of where everything is going to be mounted to help with logistics; Have a beer.
2. Get all the wiring/supplies you'll need. It's easier to run one long piece of wire than to splice it six times and add resistance across the board; Have a beer.
3. Mount all your equipment, lights, boxes, speakers, trunk trays, consoles, etc: this does not include things like partitions or transport seats that could make it more difficult to run wiring or mount other equipment; Have a beer.
4. Run all your wiring, cables, harnesses, and whatnot to the equipment requiring it, and make your connections at the load/receiving end (i.e. hook lights up to wires at the light-side of the circuit); Have a beer.
5. Mount partitions, transport seats, gun racks, and anything else left over; Have a beer.
6. Finish making connections and complete the wiring. Have a few beers and a bacon butty.
Edited for clarity.
philter74
72
Nyack, NY
Rhinojoe said:
+1
RJ
I prefer the Perma-Seal connectors. They are translucent vs the cheaper nylon heat shrink connectors, and that allows you to see that the wire is seated properly in the connector, and also that when the connector heats up and the glue melts that you have a complete seal.
36: Search: perma-seal - Page 1 of 2
I also only use an electric heat gun, I find it is very easy to burn the wire or connector when using a butane torch.
factorone33
492
Merriam, KS
JazzDad said:
Edited for clarity.
Actually, a better edit would've looked like this:
1. Have a beer.
2. Have someone else do the install for you.
3. Have all the beers.
:D
Thanks,
Ocean17
On one hand, I've agreed with this logic, but on the other hand, the other school of thought is the integrity of the connection itself. In 1994, GM began recommending that for all automotive applications, all wiring connections be crimped, solder, and heat shrinked to ensure a 100% patent connection that was protected against moisture, vibration, and force-induced breakage.
While I think it's a bit overkill to go so far as to do every connection on a vehicle, if I have to make an extension to a power lead (e.g. bigger than 14ga), I'll usually crimp and solder to prevent resistance loss. With LED loads running as low as they are today, it's kind of unnecessary to do that with smaller sizes, and maybe there's some creedence to the idea mentioned by Ocean17.
+1 on the Perma-seal connectors and the heat gun. Heat guns also don't require butane after a few weeks' use. ;P
AJ3814
689
Central Louisiana
I would just like to say thank you to everyone who has shared input here. I have been in and around LE my whole life, and will soon be wiring my POV and want to make sure it is done correctly. I have a 2015 4Runner and live in Montana. Due to weather I am a BIG proponent of rotators. I HATE strobes, and tolerate LED's. This has been VERY informative for me and am grateful for all the information shared here. Thanks folks!!
Liebman424
