So I pretty much know the basics but and having a hard time trying to figure out how to wire all my lights using the Whelen PCC8R control head.
My lights are as follows with the color/function of wires:
2 Whelen LINZ6 (grill lights)
- White/Vio = Scan Lock
- Grey = Sync
- Blk (12v) / Blk White (24v) = Ground
- Red/White = Battery (3a fuse)
SNM Eclipse Interior Bar
- Red = (+) 12V on/off switch
- Blk = Ground
- Blue = Momentary Flash Pattern Select
- Yellow = Sync Wire
SNM E66
- Blk = Vehicle ground
- Red = (+) Battery
- Purple = Warning Flash Mode
- Yellow = Right Arrow
- White = Left Arrow
- Combined Yellow/White = Center Out
- Blue = Flash Pattern Select (for what ever function above activated at time)
For some reason I cannot post photos but my controller has 8 buttons (4 top and 4 bottom).
Starting from top left to right I want the functions to be the following:
1 - All front lights (LINZ 6 & Eclipse)
2 - Rear (E66)
3 - LINZ 6 Flash Pattern Select (Momentary)
4 - Eclipse Flash Pattern Select (Momentary)
Now bottom left to right:
1 - E66 Traffic Advisory (TA) Left
2 - E66 TA Center Out
3 - E66 TA Right
4 - E66 Flash Pattern Select (Momentary)
I need help figuring out wiring to controller, what size wire I'll need, and where to fuse along with what amp fuse. Anyone that could help me (especially those that have wired using the Whelen PCC8R) I would greatly already it. Thank you in advance!
- Grey = Sync
- Blk = Ground
SNM E66
- Red = (+) Battery
2 - Rear (E66)
3 - E66 TA Right
