'14 ram 1500 Horn Ring Transfer Help
firebuff17
776
CT
Afternoon all
So I got a new '14 Ram 1500 that I want to put my Whelen PAP112 into. I popped the hood and was poking around to find the OEM horns that I can tie into for my SPDT switch to make the transfer. For the life of me I can not find them. There is a lot of plastic and coverings in there.
Does anyone have knowledge of where they are? How about in the cab? What color and location is the wire from the steering wheel?
I searched the forum here but could not find any helpful threads yet.
Thank you
Lighten
41
Georgia
Try pulling the drivers side wheel liner and look on the inside of the fender towards the door. Dodge puts them there on most of there trucks, at least diesels they do.
firebuff17
776
CT
Thank you. Will check that out in the am. I was looking everywhere in front of the tire. Didn't think they would put it that far back. Thanks again
OVERKILL
448
hamilton ontario canada
horn wire is dark green with purple stripe in the column harness it will be in a separate bundle of about 5 wires also this info is good for the 2013 I haven't updated my software yet for 14 model year but it should be the same also its neg switched
firebuff17
776
CT
AutoDetailer said:
You can get the horn trigger inside the vehicle at the BCM under the driver dash, in a black 24 pin plug (A), pin 23. The wire is dark green/white (positive trigger).
Hmmmmmm. Will look into this. I need a positive trigger and inside the cab would be beneficial. Thanks for the info
firebuff17
776
CT
Yea. I have used a relay in previous install. I was hoping this one would be a simple "plug and play" and not needing extras. Thanks
ErikH
