Muxlow
Well! My first "real" install.
Tow truck company wanted me to upgrade their current... "lights" to something better. All they had was a Able 2 mini mag mount on the back rack that was on a solid flash, and about 8 little crap china soft lights in the front window.
Front window has about 2 inches of tint and in the day time couldnt see them china lights at all... Couldnt really see them at night either.
So! They wanted better. We went with a set of Amber/White Cannons, 2 Amber/Amber T6's, A/W/A/T/A/A/T/A/W/A Pegasus, White Cannons and a SWS Directional Bar.
Removed the push bar and head lights. Poped in the the Amber/White cannons in the headlights, sync'd em up and had them alternating white/amber at first but changed it to a amber/amber white/white. Might change it back later on.
T6's i had beside the Ford emblem on a split pattern. Was some cool looking faster patterns but went with a slower one. Had to make my own mounting bracket for it
Pegasus is on random. I left the pattern wire extended so the guy can select what one he likes the most. Take Downs come on when a different switch is pushed. Also had a issue mounting it in. The sun visor was really long so couldnt attach both brackets to each side. So still have to figure out what to do there. Tow truck owner said its ok it dont bother him at all. Told em once i figure out a way to mount the end parts ill let him know and fix that up. Ideas?
White Cannons in the reverse lights. 2nd function goes solid white when the rear lower flood lights are activated
SWS Directional bar on the back rack
Able2 roof light had a solid flash pattern. Changed it to a mix of solid and flashing.
He had a 4 switch federal signal box so i just reused that.
Switch 1 Activates all front lights and rear cannons.
Switch 2 Activates the rear roof flood lights and enables the Pegasus take downs to alternate
Switch 3 Activates the bottom rear flood lights and puts the rear cannons in steady burn
Switch 4 Activates steady burn on the Pegasus take downs
The SWS controller fit perfect in the little cubby hole thing so i stuck it there since it was a good fit.
All the wires have butt connectors if need be, all zip tied and wire loomed. Only part that didnt have loom was from the control box to the dash since i didnt have one the was large to fit over all the wires.
Gave the truck back and the guy loves it. I asked if he wanted a little more warning lights in the rear, maybe another set of Amber T6's for the left and right of the directional bar but he said the roof light, cannons and directional bar should be good at night for him and in the day.
Next he wants me to upgrade their 2 flat beds. One has a Code 3 MX3000 lightbar thats it. Another has D&R Electronics Prowler. So he is looking for another set of Amber/White cannons, plus white for the rear, 2 Amber T6's for the grille and a 42 inch Feniex lightbar with a red directional bar build into the rear for the 2006 International Flatbed. Looking forward to doing that one
Took a few random videos. Added em all in with good ole movie maker.
Cant see the china lights at all in the video..or really in person either.
Tip? Comments? Bashes? Ideas? Anyone know a way to mount the end parts of the Pegasus?
Video is uploading so add it once its done
