2010 Charger 100+ Pictures
Nov 21, 2010
440
Pelican Rapids, MN
2010 Dodge Charger
Front lighting:
Whelen LINZ6 x4
HLF (OEM)
Whelen Liberty
Whelen mirror beams
Side lighting:
Whelen LINZ6 on partition
Rear lighting:
Whelen dual avenger
Whelen vertex x4
Whelen LINZ6 x2
TLF (OEM)
Misc. equipment
Pro-gard X push bumper and skid plate
Setina partition with recessed panel and vertical gun mount
Havis console
Havis computer dock
Havis Trunk tray
Canfield spare tire bracket
Whelen 295HFSA6
Mobile vision VHF system
VHF radio
800 MHz digital radio
http://picasaweb.google.com/112784668068767567210/2010DodgeCharger?feat=directlink
This is a-z of this up-fit.
7,072
Tunkhannock, PA, USA
I see you have a "12 Volt", and an "Ignition" fuse panel... How are you running that large of a main power to thie Ignition side...? Relay or something else...?
May 25, 2010
7,072
code4services.com said:
Triton-
I just tie the 3 20 amp ignition feeds out of the police power harness together and feed my fuse block with them.
Ah, so it's something thats already there... It would be nice if all cars had a couple of those floating around... LOL
Nov 21, 2010
440
Pelican Rapids, MN
Yeah, it's already there. I typically use a relay fed off off of my +12 fuse panel and triggered by an ignition circuit. I do install a 50 amp circuit breaker to protect the +12 and ignition circuits in the police power harness which is significantly lower than the 120 amps they are rated for which helps cover my butt with the tying together of each set of the 3- 20 amp wires.
Fast LT1
2,017
Sedgwick County, KS
OH MY GOD! Minus that wrap around push bumper (never cared for those) this is the best charger install i've ever seen!
Station 3
Edinburg Texas
Dont like the bumper but that damn car looks mean bro i like it. :)
RL1
1,647
Ga
I think a Go Rhino PB would look better, as well as a little bit more of an angle on the farthest out LINZ6's. Plus, I would prefer a newer radar like a Golden Eagle SD or Gen 2.
Nit picking over, that is a beautiful car. I love the lights on the side of the cage and all the install pics.
LLS
517
NYC
I love the car, but that push bumper makes the car look like it has one of those old braces harness that you had to wear at night.
TheGatekeeper
1,734
France
Awesome... And is this garage your workshop ?
Just for my information, and don't answer if you deem it innappropriate, but how many hours did you roughly spend on that car from start to finish ?
Nov 21, 2010
440
Pelican Rapids, MN
Kind of embarrassing, but the garage is my current workshop. I have plans of building a 40x60 building on my property this summer that will be a proper shop with a hoist, 12 or 14 foot side wall and much more....
I put about 30 hours in this car. Pretty slow for me, I have larger fleets of chargers that I do in 16 hours since they are all the same and I have done many of them. They have much less lighting also. This was the first time I have installed this bumper which took me way longer than it will next time.
TheGatekeeper
1,734
France
Not embarassement meant. You gotta start somewhere and frankly, it looks like a pretty neat work area to me !
16 hours... jeez,would be more like 16 days for me ! Great work, best of luck to you Jared,
Keep'em coming !
JohnMarcson
May 7, 2010
10,926
Northwest Ohio
The only suggestion i have is to find a way to angle the LED on the cage/partition down some, it's pointing up at a pretty severe angle.
JohnMarcson
May 7, 2010
10,926
Northwest Ohio
I thought about this toward the end of the build and never got back to it since I already had more labor $$ into it than customer had hoped.
Looks nice through.... good install.
Ben E.
Iowa, USA
WANT XPUSH!!! I think if I had one of those on my impala it would raise the rear tires off the ground though.
Oct 27, 2010
279
Irving TX
Great install. A+
What are you using to seal the lightbar cables, and does it come in other colors?
Nov 21, 2010
440
Pelican Rapids, MN
Bigredinstalls said:
Great install. A+
I usually use silicone, but this one is an experiment with 3M Strip Caulk. I'm not sure if it comes in other colors, but I doubt it since it is paintable. The reason I have experimented with this is that it removes cleanly when silicone is a pain to remove. The downfall to the strip caulk is that it never sets up so if it gets disturbed it has to be molded back into shape. So far on the test vehicles I haven't had any complaints.
ani216
6
Florida, USA
Awsome job!! I have a question though, im getting ready to install a siren, 7 port switchbox, ham radio, EMS radio into my car and i know how to install everything, but my questions is this: I have a cheap pair of crimpers right now for the crimp on female disconnects for the fuse panels, what would you recommend to use? or what are you using? once again..excellent job :)
Nov 21, 2010
440
Pelican Rapids, MN
This page should help. Look towards the bottom of page.
http://www.elightbars.org/forums/showthread.php?312-Solder
joecfd1
