2010 Silverado Liberty
Blask3
11
Ansonia, CT
I just acquired a Whelen liberty bar and I am going to be installing it on my 2010 Silverado crew cab. Does anyone have any tips for running the wires so I dont have to drill into the roof? I am planning on putting the brain of my controller under the rear seat. Thanks.
Mattdecker
1,172
Barren County, Kentucky
Run the cables between the cab and the bed of the truck.
There should be a vent in the back of the car that you can feed them through to the brain of your controller.
Doyle257
658
Cheektowaga, NY
I usually run wires between the cab and bed, then through a weather sealed grommet in the floor for the control cable, and run the power cable under the truck, directly to a solenoid, or directly to the battery, dependant on the customers requests and specfications.
Blask3
11
Ansonia, CT
If I run the wires between the cab and bed like you suggest is there a way to secure the wires on the roof. I would like to keep them away from the rear window if possible. I had thought about running them down the B pillar and into the boot that is between the cab and the rear door. Is this a possible option?
ErikH
