2011 Acadia
StEaLtH2
2,159
New England
Has any member ever done an upfit on a 2011 GMC Acadia?
I have specific questions if so....
Thread to progress to a build216641
StEaLtH2
2,159
New England
Tentative (although not complete) Equipment
Front
Visor-exploring options, friend had split Feniex Visor but too big :(, claimed it was universal but I don't think it was (what fits??0 currently a Talon R/W on coat hanger slick mount
red cannons turn light housing (if they fit?)
Fusion 40's R/W grill
would like to wig wag DRL's w upgraded bulb (have the HID's so inner bulb is DRL only)
speaker (Whelen freebie from Dept)
Rear
red cannons outer clear housing (if they fit?)
Fusion 180's R/W on plate bracket
Fusion 600 Red upper rear
911EP LS12's R/A rear side windows
Controlled by Star Signal LCS880
slide #1 rear warn
slide #2 front warn
slide #3 add white (front only)
aux #1 Left arrow
aux #2 Right arrow
aux#3 Flood
aux#4 Cruise (cannons front/rear)
GLUpfitting
12
Michigan
Front
Rear
slide #1 rear warn
slide #2 front warn
aux #1 Left arrow
aux #2 Right arrow
aux#3 Flood
Hey StEaLtH2,
Nice vehicle! Just thinking here...If that universal ILB didn't fit, I would try a dual mpower windshield shroud. We use them often, quick and easy install. You could do one in the middle behind the mirror, or two on each side that will sort of give it that ILB look. 2 dual color mpowers with the shroud would be around $242...if you PM me I can probably work with you on that though.
217146
Also, I've flashed the Halogen Fog's on these... I stay away from any HID/Projection. A HLF will shorten the life of the shutter a bit.
Hope that helps!
Ken, EVT-C
Reactions: StEaLtH2
StEaLtH2
2,159
New England
Thank you for your reply, just to clarify, my DRL‘s are in the traditional highbeam location on the insides and they only have a small incandescent bulb in there I’d like to upgrade them to LED bulbs and wig wag them. It will not be the HIDs. I just need to verify if the DRL’s are ground or positive switched.
StEaLtH2
2,159
New England
Got the 600 “mounted” yesterday...
Have a buddy with a pass side inner edge from 2010 explorer I’ll be test fitting this week. More to come...
StEaLtH2
2,159
New England
217471
Order placed with Fever inc...
Pulled a tail and plenty of room for what I want to do. Unsure on optics, going to try one of each to settle my debate.
Reactions: Sparky_911
StEaLtH2
2,159
New England
Progress, I tried one of each optic for the rear cannons, which are now installed. 120 it is. I’ve got some time cutting and bending and tweaking the inner edge but it’s not in. I’ve also decided against the drl as flashers. Housing issue due to poor engineering Probably will do the fogs while the nose is off. So tempted to jam a Hammer under that bumper cover.
What’s a good “small” light to cast down from open hatch? Not insanely bright
StEaLtH2
2,159
New England
Well thanks everyone for playing along.....
Install is picking up steam. Rear plate, 600, rear haw’s, and right rear window LS12 in and cables routed. Brain mounted and just fished cables forward, I’m as far as second row seat, tomo left rear window and powering up LCS880 hopefully. Pulling the nose and the visor once I line up a helper and some spare time.
Ha!! Like that really exists...
pics and vids will follow as well.
StEaLtH2
2,159
New England
Sooo, today we got the left window and wired in my brain. All rear lights are now run thru the LCS880. All rear paneling is now reinstalled and buttoned up. Test fired the speaker I was given, works
The 600 plays nicely with the siren, L/R/CO all via one button. Had to knockoff due to rain, more to follow...
Wire nut is temporary?
StEaLtH2
2,159
New England
rear plate and cannons on single slow/left-right.... finally not raining here today...
StEaLtH2
2,159
New England
Heavily modified bracket almost tweaked proper...
StEaLtH2
2,159
New England
had to take these bad larry’s out and set patterns, verify they will not change patterns at random since I have the same luck basically as Jarred..
  • Haha
Reactions: Jarred J.
StEaLtH2
2,159
New England
5/23/19
A huge thank you/shout out to @SafetyLighting for assistance with my build!
Anyone in the south eastern Massachusetts area, he’s your man.!!
Some pics to keep the savages at bay..!!!
ErikH
