2011 Dodge Durango Citadel - ***NEW INSTALL***
TritonBoulder47
Guru
Original poster
May 25, 2010
7,061
Tunkhannock, PA, USA
First off, I know its been a long time since I've been on the boards... Life kinda got in the way with my son being born, so he took all precedence.. lol
Anywho... I still have the Durango, and it still has the blue set-up on it (51" FedSig Valor, 911ep TDWL39 in the grill, Feniex B/W Cannons in the reverse lights)
But this is a different build for the Durango... Recently I got promoted in the FD and given clearance to run reds/siren, so here's what I got (so far)...
Front:
- FedSig ILS, all red, was a solid bar, but I custom split it to fit my windshield. I was nervous that my tint strip would effect the light, but it punches through no problem and hides it nicely... lol
120203959_335428067569828_8112677855058015584_n.jpg 120200687_1044498912677948_3582375473343742222_n.jpg
120012413_2405834573053612_1202665570634112396_n.jpg 120191796_1096084190788747_669912000046972821_n.jpg
- Whelen UHF-2150 HLF
Sides:
- Feniex T-300s, R/W/R, custom made by me using dummy T-4 heads running off of a Whelen ULF-44
Rear:
- FedSig ILS, all red, only had to some slight trimming to the outside edges of the shroud/frame, and remove the outer reflectors to get it to fit. I may try and trim the reflectors and get them back in the bar. Tucks up perfect on the top of my liftgate.
120253444_361514265258518_6242933953253953833_n.jpg 120223251_791726744909495_6631391278918402027_n.jpg 120263635_345283306529868_8705703026078910418_n.jpg
- Feniex Cannon 360s, red, in the tail lights.
Controls:
Feniex 4200 (for now)
Currently for a Siren I'm running a Sho-Me (I believe) undercover siren (that I found in my menagerie of equipment), and a Whelen Speaker on the Whelen Durango bracket. I have the A/H run off my Feniex 4200, and I found an ON-OFF-ON switch to run the siren tones until I can find a different siren/light control device. Thinking of a CenCom Just so I can have a PowerCall type siren... (Flame all you want, I like PC)
Waiting to be installed:
- Feniex F12 Apollos, R/W, to be installed under the mirrors
- Feniex Fusion 180s, R/W, to be installed on my 1075 License Plate Bracket for Intersection Warning
Still Want:
- A pair of grill lights... Not sure what I want for grill lights, but something with a large footprint
- Siren/Light controller. I want to keep my 4200 and use that for my Blue set-up and get something separate for my Red set-up...
And of course, what you've all been waiting for... The Video!!! I'll take a better one in a few days, this was just a quick walk-around...
And yes, I know that one head on the drivers side of the ILS is out... I've tried everything I could to get it to work, but I think its a dead section... So if anyone has a line on and ILS Inner Drivers side board, I'm interested...
silverunicorn
185
USA / PA
Welcome back! Nice setup and use of existing equipment modified for the Durango. I recently got my Durango done too (after 4 years) LOL.
Congrats on the promotion and the new addition to the family!
Chris
Reactions: TritonBoulder47
TritonBoulder47
Guru
Original poster
May 25, 2010
7,061
Looks good man! Glad to see you back around here
Thanks man... Good to be back!!!
Chris
Thanks man!!! Your Durango looks sweet too!!!
TritonBoulder47
Guru
Original poster
May 25, 2010
7,061
Added some intersection warning over the weekend...
I found my 1075 LP Bracket and planned on installing a pair of R/W dual dolor Feniex Fusion dummy heads on it... Well after installation and wiring, the heads weren't acting like they were supposed to, so I removed the Fusions and installed a pair of R/W dual color Feniex F12 Apollos instead...
120966889_710187392915010_1107487219355785434_n.jpg 120894404_1205305556535354_3887103506337073040_n.jpg
TritonBoulder47
Guru
Original poster
May 25, 2010
7,061
Next up for install...
120764684_365008667969677_4433595771202929662_n.jpg 121034190_3531263453603092_2347659900369759603_n.jpg
Since these didn't work as intersection lights (might have been a compromised wire in one of the runs from the rear to the front. When I first started installing items on the Durango I installed multiple extra wire runs for expansion and such) I'm gonna use these at my mirror lights... I think these will work better for mirror lights with their bigger footprint, plus I found a pair of Feniex swivel brackets floating around in my stockpile of parts. Hopefully I can get these installed and wired on my next days off. These should help give my that little more side warning that I think the install is missing...
Other than getting a siren/controller for my red set-up, this install should be done (for now...? LoL)
Reactions: Tony P
RyanZ71
Senior Member
Jun 14, 2011
980
Denver, Colorado
any way to get more of a left/right flash pattern with the Reds? I think you'll get better attention that way vs the "blob" that it appears like right now. You have the right type of light heads, just need the patterns synced a bit and then you'll have a very lean mean... Durango! I like it otherwise!
Reactions: Krsdog25
TritonBoulder47
Guru
Original poster
May 25, 2010
7,061
Trust me, if there was a way to sync it all, it would be synced... Theres no way to sync the ILS bars with any of the other lightheads in my set-up. Plus the Feniex lightheads (Cannons, and Apollos) don't work well with external flashers.
The lights in my rear side windows, mirror lights (when Installed), and grill lights (when installed) will be all synced because they will be run off the same flasher (ULF-44).
The Front and Rear ILS bars are synced with each other, because they are fun off the same CID box, but they can't be synced with anything else...
The Apollos in the front and the Cannons in my tails can't be synced with the other stuff... I might be able to sync the Cannons and the Apollos together, depending on their build dates/firmware.
This build was 100% made with equipment that I already had laying around in my menagerie of lighting equipment. NOTHING in the build has been purchased recently, everything has been sitting in my possession for at least 2 years... lol
TritonBoulder47
Guru
Original poster
May 25, 2010
7,061
Well, upon further testing, I guess these just don't play well with the ULF-44 flasher... :(:mad:
I direct wired them to power/ground and put the trigger leads directly on my flasher and they just turn on steady...
Now I'm on the hunt for something to use in their place...
Nolines
Guru
Apr 5, 2018
1,647
Margate, FL
Well at least you were able to flash from sad to angry looks!
TritonBoulder47
Guru
Original poster
May 25, 2010
7,061
Since I have a spare grill assembly hanging in my garage, I decided to do some testing tonight... Played around with some Whelen 500s (LIN & TIR) I had laying around... Cut out a section of the "honeycomb" so that the lighthead is recessed.
This should be installed later this week depending on the weather, and If I get some flanges to secure them... Not sure of I'll add 2 more in the top grill inserts or not...
silverunicorn
185
USA / PA
Looks good to me! Can you just remove the grill on your Durango?
On mine I have to remove the whole front bumper assembly which has deterred me to add anything in the grill for mine :(
Chris
TritonBoulder47
Guru
Original poster
May 25, 2010
7,061
Chris
No, the bumper cover has to come off to remove the grill... This is actually the stock grill from my Durango. I replaced it with a color matched one when I hit a deer a few years ago... So this one is laying around for testing purposes...
I've had the bumper and grill off of this thing so many times, it only takes a few minutes... lol
TritonBoulder47
Guru
Original poster
May 25, 2010
7,061
Wasn't able to make any progress on the grill lights over the weekend... Had a cold snap, so needed to get my camper winterized and stored, plus winterize the house...
But tonight at work I got the 500 series flanges trimmed down a 1/4" so the lights aren't sticking off the grill. They not sit nice and inset in the grill sections. Hopefully later this week I can get the wired into my ULF-44.
122336960_351060452831541_1200315827855702794_n.jpg 122179910_346506076605159_5377977748273750318_n.jpg 122144537_1595998903912344_8001255597708357954_n.jpg
Plus I need to Clean up/re-do my wiring and equipment location. I kinda went "quick n dirty" with installing my red stuff just to get it running... lol I'm going to try and make a nice equipment board to clean everything up...
Reactions: StEaLtH2
TritonBoulder47
Guru
Original poster
May 25, 2010
7,061
Got my grill lights installed and wired up... Sadly, after I got it all installed and back together, I noticed that the grill lights point downward a good bit... But they are still plenty visible forward... I have to make some shims for the lights and that issue will be solved.
TritonBoulder47
Guru
Original poster
May 25, 2010
7,061
As of right now, the build is "done"... lol (are they ever really...?)
Lighting wise, I want to add some kind of mirror light on my side-view mirrors... That should eliminate the dead zone on the side... The only other thing I'm thinking about is a second controlling system (CenCom, SS Platinum, 4200 etc.) so I have complete separation of my red and blue set-ups, and possibly a newer siren system...
Reactions: JohnMarcson
TritonBoulder47
Guru
Original poster
May 25, 2010
7,061
Copy thanks. I have a 2012 that I was looking for a flasher for. Hesitant to use ZFlash or Speedturtle.
I actually made my own "No-Splice" HLF... Pretty much plug-n-play... Makes it so much easier when switching vehicles (as long as they use a 9005 high beam LoL)
TritonBoulder47
Guru
Original poster
May 25, 2010
7,061
Updated Equipment List: (As of 11/2/20)
Front:
- Federal Signal Split ILS, all red
- 2 Whelen 500 Series Linear Lightheads, Red (Run off of a Whelen ULF-44)
Side:
- 2 Feniex F12 Apollo Lightheads Red/White - Mounted on a 10-75 Intersection Bracket
- 2 Custom made Feniex T-300 Lightsticks, Red/White/Red - Mounted in the rear side windows (Run off of a Whelen ULF-44)
Rear:
- Federal Signal ILS, all red
- 2 Feniex Cannon 180s, red - Mounted in the tail lights
Controls:
- Feniex 4200
Siren:
- Sho-me Undercover siren, Wail/Yelp/Air Horn
- Whelen SA315P Speaker Mounted using a Whelen Durango Specific Bracket behind the grill
Still Wanting/Needing:
- Some kind of "mirror light" There is a HUGE dead spot in my side warning... LoL
- Second control system/siren Possibly a CenCom or some other siren/controller (ideally, something with a power call tone). Just so I have complete separation of my Red Warning and my Blue Warning.
Reactions: Tony P
TritonBoulder47
Guru
Original poster
May 25, 2010
7,061
Here's the original post I made about it... Holy crap!!! I can't believe I made this over 8 years ago... LoL
duke018
Lurking Newbie
Jun 25, 2013
66
Delaware
Nice thanks!
Krsdog25
Junior Member
Apr 30, 2012
186
NJ
I know you mentioned that you can't sync the ILS with any of the other lights, but are you able to do more of a half/half pattern in the front? I feel like you're getting more of a flicker than a punch and while it looks good up close you're probably sacrificing warning power at distance. I know you mentioned wanting grill lights with a large footprint so I assume that distance is something important to you. Just my 2 cents, otherwise a very nice package you put together there.
TritonBoulder47
Guru
Original poster
May 25, 2010
7,061
I have all 3 modes for the ILS bars hooked up:
Mode #1: Basic "wig-wag" pattern
Mode #2: Fast "center out" pattern (Video in Posts #1 & #20)
Mode #3: "Cluster" type pattern (Video in Post #7
They all get used at different times, those were just the modes i happen to put the slide switch to...
TritonBoulder47
Guru
Original poster
May 25, 2010
7,061
** Update **
Well, lately I've been plagued with some issues with the Durango... So it looks like once I get it back from getting fixed (again) I'm gonna start the tear down, and start looking for a new to me vehicle...
ALL of my stuff will be coming out... And now that I'm thinking about it, there is A LOT of stuff to remove... lol
To Be removed:
- Gamber Johnson Full Console​
- Power/Ground/Ignition Distribution Blocks​
- Feniex 4200 Which only has 1/2 the outputs working due to something shorting out in the brain. So I'm on the hunt for at least 1 new(er) control system​
- Remote Mount Motorola CDM-1250​
- Sho-Me Undercover Siren​
- Sho-Me Full Function Siren​
- FedSig Blue Valor (90% sure I'm going to sell this, no I will not shit it. Pick up or meet somewhere not too far from NEPA)​
- 10-75 License Plate bracket w/ 2 Red/White Feniex Fusions​
- 2 Red Whelen Linear 500s (grill)​
- 2 Custom Feniex T-300s R/W/R (rear side windows)​
- FedSig Front ILS, red custom split​
- FedSig Rear ILS, red​
- 2 Feniex Cannon 180s, red in tail lights​
- 2 Feniex Cannon 180s blue/white in reverse lights​
- Custom "no-splice" Whelen HLF
- 2 Siren speakers​
- Whelen ULF 44​
- All added wiring/cables​
- And I'm sure I'm forgetting some stuff... lol​
Reactions: fp13-2 and Tony P
TritonBoulder47
Guru
Original poster
May 25, 2010
7,061
Reactions: Dave F
TritonBoulder47
Guru
Original poster
May 25, 2010
7,061
Well, started the teardown today...
Items removed (so far):
- Valor w/ Cables
- Front ILS w/ Cables
- Rear ILS w/ Cables
- Rear Side Custom T-300s with Cables
- Motorola CDM 1250 Brain
- U/C Siren Amp & Wiring
- 4200 Brain & Wiring
- ULF-44
(Not back for a couple hours of work before coming to work... lol)
Still To be removed:
- Console
- 4200 Head
- Sho-me Full Function Siren
- CDM1250 Head & Mic
- VHF Antenna
- HLF
- Grill Lights
- Feniex Apollos w/ 10-75 Intersection bracket
- The rest of the wiring
- LED Reverse bar
Then I just have to put the factory center console back in, and put the chrome grill inserts back in... I also have to get a set of tail lights since I drilled out the twist/lock area of the reverse light to install LED HAWs, and since there is also a hole in the tail light section for those LED HAWs... lol
Its strange to see the Durango without the Valor on... Its been on there ever since I picked it up from Travis... LoL
TritonBoulder47
Guru
Original poster
May 25, 2010
7,061
Got the Respond-A-Laser finished up at work last night. Wired it to a ciggy plug and threw on a set of 120lb Poly-Coated mags. In retrospect, the 120s are probably overkill since I almost broke the lightbar itself when trying to adjust the bar and get it centered... lol
I'm not gonna lie... It looks pretty dang good up there... lol
And of course, a video...
Paradit
Members Online
eLightbars.org uses SSL to secure all traffic between our server and your browsing device. All browsing and transactions within are secured by Sectigo SSL with high-strength encryption.
