2014 Chevy Tahoe
Wilmington, MA
We just finished our latest install for a local police Chief
2014 Chevy Tahoe
All Lighting is Brooking / Axixtech
Front:
MS6BS Lightheads in the Grill
Par 36 LED Fog Lights
ST6 LED's on side mirrors
SV6 Stealth Visor
Whelen Police Package Wig Wag Module
Side:
PAL06A on the running boards
Modified Quad Commander LED Sticks (Cut down to 3-head to fit the rear window)
Rear:
Shadow with 7 MS6BS Lightheads
HAL09 Hideaway LED's in Tailights
Siren/Light Controller:
Whelen 295SDA1 - Dual Tone Siren
2x Whelen SA315 Speakers
Havis 10" Tahoe Console
Kenwood TK790/TK890 Dual-Band, Dual Head Radio
[Broken External Image]:[URL]http://i107.photobucket.com/albums/m287/jmartocchio/Groton%20/th_75C32689-1A92-45C5-BB0F-C584CA35328D.jpg[/URL]
[Broken External Image]:[URL]http://i107.photobucket.com/albums/m287/jmartocchio/Groton%20/C84F3F28-3655-42D7-907D-6F347AB7BD01.jpg[/URL]
acala91
1,662
FL
Looks really good! I love the sync in the front.
A few changes I'd make -
- Change the position of the grill lights so the top two are in the corners and the bottom ones about where they are now
- Change the rear lightbar configuration from B/B/B/B/B/B/B to B/A/B/A/B/A/B so it flashes amber against blue
Wilmington, MA
I agree, I recommended having 1 of the heads on the bar red, and 1 amber to break it up but the Chief insisted on all blue
As far as the grill, I was originally going to do that but it came down to ease of mounting them. When I get the office I will post a pic of the inside of the grill.
VolEms said:
How did u find the programming of the siren. We did a couple do them and found the programming to be a pain.
Programming took a little to get use to, however once I figured it out it wasn't to bad.
One thing I still haven't figured out and not sure if its possible, we had each function assigned to a single switch and then programmed the pursuit switch to turn on certain functions depending on the position which works great, however when you use the pursuit switch the indicator light for each individual switch does not light up.
bigcat
641
Hartford County, CT
Upon looking at the install PDF for the 295SDA1, I noticed it talked about remote "output" activation only, whereas if you look at the PDF for the PCCS9RW, it has sections on programming both remote "output" and remote "switch" activation. I would venture to say, that is the difference of the switch lighting up vs. staying off. I'm a little surprised that one product would have that feature and another wouldn't.
Tom
3,083
Taunton, MA
I love the sync with the front lights, the side looks nice, rear looks great, I just do not like that interior bar pattern. IMO, a left-side, right-side pattern would be highly effective.
Troop
85
East Coast
Nice looking truck. I agree with some of the above comments, but it could be worse.
tsquale
Oct 12, 2010
10,533
Minnesota, USA
I'm not a fan of the Knight Rider pattern in the front, but really like the set up overall. That rear window set up is very cool!
pdk9
3,834
New York & Florida
I love it!!! The only thing I dislike is the knight rider scan pattern on the SV up front (I feel like going up to the chief & saying "why flash all the blue modules at once when you can flash 1 by itself?")
I would've preferred a pair of double stack MS6 in the grill for a larger lighthead footprint, but it's no biggie
Wilmington, MA
AutoDetailer said:
Any chance you have dent up close pics of the mirror lights? They look small but I wanted to see how they look mounted.
Thanks
I will check. If not I can get some when he comes in next week to have his command box installed
Sanman
