I have a 2014 Impala 9C3 assigned to me, it has a 6J7 option flasher installed. The label only says "AJA20013" and was looking to disable the nighttime cutoff. My understanding is its interfaced with the BCM so the taillights flash as well, however I can't find a way to remove the nighttime cut off so that it still flashes with the low-beams on.
I can't find a wiring diagram, I know its possible because there are others that flash at night, and have the same option installed.
Any ideas?
Any ideas?
