2015 F150 SOS HLF
Eric223
Anybody have any tips on where to tap into the highbeam wire for a 2015 F150 XLT...using a SOS Solid State flasher. Aside from the obvious of taking the headlight out (hoping to not go that route as it involves disassembly of the front fascia. Thanks.
Archive Expert
Silver Supporter
Uhh did you go to sos website and look at the vehicle specifications under their links? It tells you what they are...
OP
OP
Eric223
Eric223
Yes I did. That website tells me the best flasher to use and the color of the high beam and low beam wire depending on which one the user would like to flash. It does not give any tips on what location under the hood would be ideal for accessing those wires. I know that the obvious answer is to remove the headlight, but I was hoping there is someone on here with some knowledge of an alternate location. I appreciate your input re: the website, but that isn't what I am asking for.
C17LVFD
Senior Member
Could u just do an add a harness to the existing headlight bulb plugs? Plug n play essentially. If you can get to the high beam head... no need to pull the headlight. Idk what’s involved with changing a headlight bulb with the vehicle. But the last few I’ve done, I just extended the harness using plug n play connectors... spliced into the needed wires and was done with it.
Hope that helps.
Seth
Archive Expert
Silver Supporter
That's what I did as well... I ordered two extension harnesses... Tapped into those and no Messing with factory wiring... Extensions we're 10 bucks a piece...
Latest Listings
Top Bottom
