2016 Ford PIU spotlight power issues.
11b101abn
549
Georgia, United States
My assigned unit had a cracked windshield replaced. Well, after the fact is when the glass shop decided it would be a good time to let me know that they had no experience with spotlights. They half a**ed placed it together loosely and left the rest up to me.
Now, re-assembly is NOT the issue. The issue is that i cannot locate the power source for the light. My unit came with the light installed, so I assume it came prepped for spots. I just need help locating power supply.
Any and all assistance is appreciated. Thanks in advance.
billyfromhill
143
Western New York
There should be a connector/wire mounted to the inside of the metal A pillar under the trim. The wire from the spotlight connects there although most of the time the tech/upfitter adds another connector so the handle can be removed and the wire disconnected without removing the trim.
I would also check and make sure you have a good ground.
ErikH
