Has anyone put in headlight wig wags On the new 2020 Silverado LT 2500 HD. We just ordered ours to replace the older utility . If anyone has done it which flasher and was there any issue. These new cars with everything running through canbus system don’t know if it would be an issue . As an alternative I was thinking to put white haw in the upper turn signal housing at a slow single flash alternating pattern to simulated it. I know it’s not as good as actual wigwag but
Thanks in advance
Thanks in advance
