2023 Toyota Tacoma Feniex Install Help
oloya
1
0
Texas
Hello everyone.
I will be doing a full Feniex install on my POV 2023 Toyota Tacoma and I am needing help with how the wiring will work.
Currently I have x2 Feniex QSM's mounted on the front grill and a 4200 mini controller inside. As far as wiring goes, the controller is attached to an ignition switch on my factory fuse block and all ground wires are running to a ground location in the engine bay. The QSM 3 mode wires are ran through the firewall inside the cabin near the pedals. I do not have any fuses, relays, or terminal blocks set up.
I am going to be doing an update and removing the QSM's in the front grill and adding more lights.
The lights and locations for the lights are as follows:
Front
  • x4 Feniex Q Flat Surface Mounts
Passenger Side Step
  • x3 Feniex Q3 Surface Mounts
Driver Side Step
Rear
  • x2 Feniex Quad 200 Light Sticks
  • x2 Feniex Quad Surface Mounts for License Plate Mount
The main question I had is, how do I wire everything. I would like the location of all my wiring to be in the rear cubby behind the back seat (see attached picture).
I know nothing about fuse blocks, relays, terminals, etc. I also want to set all lights to steady on and use a Whelen flasher as the external flasher. Also If anyone can make an easy to read diagram I would greatly appreciate that, as I am a visual learner lol.
Thanks for the help in advance. Feel free to ask questions. I tried to word this as easy as possible.
gotcy712000
