3 Pod Cuda LED Vector
Berlin, MI, 48002
I've spent the last few days on this thing. I cut the frame down from a normal Smart Vector that had cut cables & more assorted problems. The LEDs & brackets are out of a FedSig Raydian that I parted out. I didn't cut any of the brackets, just drilled holes in them.
Federal never used this type of LED in their 3 pod Vectors; they always used Solaris LEDs. They used 3 modules on each outboard pod - from what I can tell - one facing the rear, one facing the front & one facing the side & 2 stacked in the front center.
Mine is set up the same way but with 2 facing each side instead of one.
I'm not done with this one yet, I have all the wires pulled but still need to order new domes, a LED flasher & have to put magnets & a cable on it.
I was also contemplating angling the top LED modules on the outboard ends if space allows.
Here it is as it sits now...
JohnMarcson
May 7, 2010
10,603
Northwest Ohio
Looks great!.. what sort of flash sequence do you use?
Berlin, MI, 48002
I was hoping to run a 27 pattern sho-me flasher in it; which I don't have yet.
My plan was to put all of the left pod & the lower LED module from the center pod on the left flasher output & the rest on the right output.
I'd LIKE to run a Whelen flasher or 2 but I'd more than likely have to buy 2 of them & they're not exactly cheap.
Fast LT1
2,017
Sedgwick County, KS
911 said:
let me know when you want to sell it !!!!
Hell yea, i'd buy that faster than you can say sold!
Henry455
Houston, TX
Just curious, not familiar with the Raydian LED modules, what is the amp draw on each LED module. Remember, the Sho_me flasher is rated 3 amps per side.
Berlin, MI, 48002
I forget the rating, I did look it up though. I know the blue were more draw. *Just checked, amber modules (9 LEDs) draw 0.78 amps each.
I have 1 sho-me flasher in my arjent running 12 modules (all red).
I'll try getting a video when I get it done :)
nerdly_dood
2,312
Georgia
Looks nice! Interesting flash pattern.
drew7262
