This listing is for 4 used blue LED lights for $35.00
I do not have any other colors.
Free Shipping,
Check out my feedback and other police/fire items on eBay @ misc.electronics Payment through Marketplace, PayPal or Zelle
I have several hundred of these in stock. These are new in the package. I also have new red ones listed. Features of Whelen LED LIN3 Surface Mount Lighthead
3 Generation III LEDs with Linear Optics.
Standard Mode: 10 Scan-Lock Flash Patterns plus Steady Burn. Sync Mode: 7 Scan-Lock Flash Patterns each with Phase 1 and Phase 2. Four Wire Synchronizable Version. Fully encapsulated for vibration, moisture and corrosion resistance. Black Surface Mount Flange Included Standard. Designed for Horizontal Mounting.
Dimensions: 3-5/8" W x 1-5/16" H x 1-5/16" D.
SYNC Flash Patterns: 1. SignalAlert™ 75 Phase 1
2. SignalAlert™ 75 Phase 2
3. CometFlash® 75 Phase 1
4. CometFlash® 75 Phase 2
5. DoubleFlash 75 Phase 1
6. DoubleFlash 75 Phase 2
7. SingleFlash 75 Phase 1
8. SingleFlash 75 Phase 2
9. ComAlert™ 75 Phase 1
10. ComAlert™ 75 Phase 2
11. LongBurst™ 75 Phase 1
12. LongBurst™ 75 Phase 2
13. PingPong™ 75 Phase 1
14. ™ PingPong 75 Phase 2 Regular Flash Patterns:
15. SingleFlash 60
16. SIngleFlash 90
17. SingleFlash 120
18. SingleFlash 300
19. DoubleFlash 150
20. ComAlert™ 150
21. ActionFlash™ 1
22. ActionFlash™ 2
23. ModuFlash™
24. ActionScan™
25. Steady Scan-Lock™ -
Each flash pattern is available in two modes; Phase 1 & Phase 2. The patterns are controlled with the WHT/VIO wire. To advance to the next pattern, apply +VDC to the WHT/VIO wire for less than 1 second. To cycle backwards, apply +VDC for more than 1 second. To reset to the factory default pattern, turn off power to the light head and while applying +VDC to the WHT/VIO, turn the light head back on. Continue to apply voltage for 5 seconds. LIN3 Whelen LED’s Emergency Vehicle Lights are Encapsulated, low current and tough as nails so they’ll go to work for you anywhere on your vehicle, shrugging off moisture and road vibration. Perfect for mounting in the grill, on side mirrors, on bumpers, over steps, on motorcycle boxes and fairing, on ATV’s, forklifts and material-handling vehicles ... Wherever high intensity, wide angle warning is required. Highly effective LIN3 Super-LED surface mount Police Light module with black ABS mounting flange. Optional chrome ABS mounting flange available. Tiny size, dozens of applications Super-LED tough, low current, vibration and moisture resistant. Available in steady-burn, 15 Scan Lock patterns, 10 Scan Lock patterns and synchronization capability Available in all four safety colors. Five year warranty. Please call for vertical mounting. Great Product for Emergency Vehicle Lights
Free Shipping,
15. SingleFlash 60
16. SIngleFlash 90
17. SingleFlash 120
18. SingleFlash 300
19. DoubleFlash 150
20. ComAlert™ 150
21. ActionFlash™ 1
22. ActionFlash™ 2
23. ModuFlash™
24. ActionScan™
