Wanted 50-60 inch light bar frame or full
LenH
138
Texas
Needing a 50-60” (or longer) lightbar frame with or without domes and internal parts. Color is no issue. I’m needing two of them for large trucks I will co wider any of the following. But open to some other possibilities. I have a bunch of whelen 500 series strobe lights as well as a few dashking heads that I am wanting to use inside of a light for a dump truck and a wrecker but can’t find a long enough bar locally. Thank you for your consideration.
Code 3: Mx7000-excaliber-2100-360-ranger-Rx series-intensity-lp6000
Federal: jet series, vista
Whelen: edge, justice, centurion, liberty style
SVP/star impulse, interceptor, starbar
soutthpaw
135
Sparks, NV
I just weld the frames together. This is an 80" project Excalibur that will take 4 center sections. I have everything to complete the build with front and rear arrowsticks. I have Excalibur, MX7000 and Whelen edge bars that I can join.
LenH
138
Texas
I’m no good st welding but I wonder if I could have this done somewhere in the Texoma area
Southern5
25
Ozark al
I have an mx7000 frame if you haven’t already got what you need.
Reactions: LenH
mike2459
120
South Glens Falls,NY
Will these work? a little pricey....https://www.mpshighwaysafety.com/store/p185/product-fs_mounting_bars_kits.html
LenH
138
Texas
Negative. Not wanting a cross bar, wanting bar frame that lights go in but I like the idea of southpaw so I may go with that and use some of the short ones as add ons
