k.mo
Looking for advice/help!
Couple of things..
1.) do CID serial/millennium serials need to match? In example:
• CID S/N: AH0509AI0112
• CID S/N: AH102607AI01012
•Mill S/N: AH0152AA0805
Should the format of the first four numbers matter?
Secondly, if I’m getting a solid red light one CID but not the other does that suggest an problem with the CID or with the millennium?
The issue I’m running into, is that on the CID WITHOUT the error light, there is a burn mark on the board from the 12v side of the equation, and thus only intermittently powers/warns when the switch has all functions open (toggled to power) and the other CID WITH the error light won’t warn period due to the communications error.
Any help out there?
Couple of things..
Any help out there?
