911ep millennium question help please
Sta25ems
4
Lancaster pa
I have the last new version of the 911ep millennium light bar with the new cid. Now I just got it a few weeks ago and it worked fine. I went to install and seen one module was out then the whole bar won't light up. When I connect the wires some of the modules come on for a very split second then nothing. The controller lights up along with the power light to the cid but the N opplight does not come on like it did before I installed. Any help would be appreciated thanks.
tsquale
Oct 12, 2010
10,533
Minnesota, USA
@Sta25ems are you sure you have it wired back up correctly? RX and TX wires aren't mixed up? Good ground and power source (not a jumper pack).
Here is the install guide.
  • 640004CID_InstallGuide.pdf
  • Millennium_InstallTabloid.pdf
Reactions: Tony P
arnold gonzalez
