911ep STAR 360 all red
Due to a vehicle change and some budget constraints, I've chosen to part with my star. Not made anymore and I've yet to see a website list these for less than 165.
Very low use - used only once since re-wire.
Was a perm mount, converted to magnetic.
All red (4 quadrants, each one is red)
I researched, located, and purchased the correct wiring block to convert this. This came wired with only a few functions and no pattern change. The cable plugged right into the bottom of the light and was hardwire only. I bought a pattern switch cig plug cable, soldered it to be ground switched instead of positive switched, and soldered the wires to the correct pinouts on the terminal block I bought. Now, the wire and block just plug into the bottom of the light. Comes with a magnet (I can find the lb. rating if you want). Only thing you'll want to do is choose your magnet spacing and seal the wiring with some silicone.
Video of unit:
https://www.youtube.com/watch?v=lXGhlPmrgnc
This is listed in panjo but I would rather not get hit with 10.35 + 4.65 in fees.
Paypal is shadowthatmoves@gmail.com
Would be willing to trade for a Cobra 400 red/red/red/red
List Date: 9/30/2016
For more info, click here to view the original listing: 911ep STAR 360 all red
This item is no longer available.
Video of unit:
