911ep
REDDPSE
Central Ohio
are all 911ep ls12s capable for exterior use???
i dont know too much about them.
911ep would beg to differ...
Newer style is listed as interior/exterior mount.
http://www.911ep.com/products/ls12.asp
The older style came in two versions. One had a cable with multiple wires to power the unit/change flash patterns. This one was able to be exterior mounted. The other version had a cigar plug/pattern switch on the light. This one was interior mount only.
this one is the newer model with a cig plug,
andy is there anyway you can find out if i gave you the SN?
cory y said:
no... they arnt sealed
Of course they are. ALL of the new ones are made the same; the only thing not waterproof is the switch and you can cut that off. Just be aware if you do, you may have warranty issues.
Jmann639
