9M strobe power supply - help
got_yogurt
BC, Canada
Does anyone know what each of the 6 wires does going into a 9M supply? I'm guessing black is ground, Red is power? Then are the rest positive triggers for front/rear, scan lock, and ???
I'm trying to make my own mini bar and I don't want to use the power distribution board from the 9M, just want to wire in one strobe power supply.
Pete L.
Virginia (south/central)
Red - power 12vdc
Black - ground
Green - power for one pair of strobes (+)
Blue - power to the other pair of strobes (+)
White - scan lock pattern wire (momentary +)
Violet - low/high power function (I can't remember if its (+) for high or (-) for high ?)
        I'm sure another member will chime in.
-Pete
ErikH
