One way to make an alternating flasher is with a relay and a two prong flasher. I know there are other ways, but I had a specific question about how to alternate a two prong flasher and I figured I would share my fix this way.
Really, just buy an alternating flasher. They aren't expensive and the relay and thermal flasher together is a recipe for failure. But....if you want to try it, here is a way.
Hook up one lamp to the thermal flasher, then wire the thermal flasher output to that light to the trigger of your relay. Hook a second light to the normally closed (powered by default) side of the relay, and when the first light is flashes it will open (turn off) the normally closed (on) side and the light will turn off opposite of the light on the thermal flasher. Now you have the clicking of a thermal flasher and the clicking of a relay. Harmony?
