Adamson industries deck lights wiring
solidamber
16
cambridge UK
Adamson industries ai35cvrb led deck strobes, they hav 4 wires red and black for power and a white and green. Does anyone know which wire changes the flash pattern? IMG_20181118_012747.jpgIMG_20181118_012728.jpg
C17LVFD
Harrisburg, PA
Those actually look like star signal product housings. Maybe rebranded adamson??
You could deduce that red is positive and blacks are negative. Likely white or green is your pattern wire. Are both whites or both greens connected together? Can’t discern from the pic. If one or the other are tied between light heads pull them apart and see what happens. If they unsync u have your answer. Always try grounding the pattern wire prior to giving it 12v. Whelen uses positive triggers but I feel like most other manufacturers use negative.
Good luck,
Seth
Reactions: solidamber
solidamber
16
cambridge UK
Good luck,
Seth
Yes red and black are as expected white and green have been cut off I guessed one or the other would be the pattern wire but didn't want to start grounding or giving them voltage in fear of blowing the board.
airflores
