Adding additional strobes to Whelen Edge bar
I’m looking to add at least 2 more strobes and maybe halogen flashers to my current 48” Edge 9000. Currently it only has 4 corner strobes and that’s it. Sitting in my garage I have a 60” Edge bar with front facing strobes, as well as flashers. What would it take to make my 48” bar, take these front facing strobes and flashers? Would I be able to pull the modules out of the 60” and swap them over with the strobes/flasher heads? Would i need to run new wiring to my switches in my truck where my 48” is installed now?
Parts swap should be straightforward. Question is...do you have enough power supply outlets and halogen flasher board.
Well that’s basically what my question is, if I can swap the power supply’s and flasher boards from the 60” to the 48” on my truck already so I can add these lights? Because like I said if I do then what of all my wiring running to my switch in my truck needs to change?
Theoretically you can switch them. Idk if ur edge is high power or low power that changes the dynamic slightly. Mixing low power n high power setups is more difficult.
Assuming it’s high power you’ll likely have to hook up the additional trigger wires at both ends of the wiring harness to run power from ur switch box to the additional strobe heads / flashers.
Factor 10a per pair of halogen flashers and 10a for a 4 pack of strobes (double check that though as im going off the top of my head).
Seth
Code2LLC
