Aerodynic wrecker bar
Berlin, MI, 48002
I picked this up on a trade today. Haven't done anything to it yet other than bring it inside.
Appears to be a 25RWLI. It has 2 independent rotators, S/T/T lights, work lights, front flashers & the usual smashed up DOT light strip. & the domes look like stained glass. 1 endcap is hanging off, the other is broken off & the lenses on the front/back next to the bad endcap are also broken. OH & it has hex bolts in the frame for endcap screws......
Life of a wrecker bar....
Wailer
2,293
Canada
The early ones had two dual sealed beam rotators and the later ones had two rotating reflectors.
Jun 18, 2013
3,717
PA
If you cant rehab the rotator let me know. I have some federal Hawk type rotators sitting around you might be able to use.
Jun 18, 2013
3,717
PA
The SAE date is just the date of the certification. Those should have a date on the motor, that date is very close to the build date.
Did they still do this with the Aerohawk independent rotators?
Jun 18, 2013
3,717
PA
Anyone have any pictures of this?
I would need to pull one of my Aerohawks out to confirm. I did not know this.
Berlin, MI, 48002
Here it is...domes came out OK. However there are scuffs, other small damage that will probably never come out. I managed to free up the stuck rotator too. Still need to somehow bend the DOT strip bracket back into place. REALLY don't want to remove it from the frame & risk breaking the screws...
Also changed the bulkhead out to a less broken one. The original was broken in several places.
jaf10596
