localhero800 Veteran Member May 22, 2010 1,333 1 Southeast Missouri Jul 13, 2010 #1 I have a icom f320 installed in my truck. I can hear a whine when it is recieving a transmission. it varies with the RPS of the motor.. Presto==---- Alternator noise!!! How do i correct this>> the radio is direct to the battery.
S shues Lifetime VIP Donor May 21, 2010 10,555 871 NW Indiana Jul 13, 2010 #2 I had an alternator noise one time with mine when I had a bad ground. The radio was grounding through the case instead of through its ground wire. Make sure that your ground is better than good, and as close to the radio as possible. Also, make sure your coax is of high quality and has no pinches or exposed shield or tight loops.
localhero800 Veteran Member May 22, 2010 1,333 1 Southeast Missouri Jul 14, 2010 #3 Yep.. thats it.. i ran the ground to the battery.. i need to run it right to a lug on the console..
