Another Smart Siren Problem
xcharger95x
27
1
NYC
So I recently installed a ss200 with a ss2000sm brain, ran all wiring for lights with proper connections, grounds etc. lights were all working and keypad was functional. Went to chirp the yelp, the key pad turns off, no power. All fuses are fine, circuit breaker are fine and tested with jumper. Tried another brain, nothing. Tried another full size ss2000 pad nothing. There is power to the fuse block where the brain is connected, fuses on truck fuse block are fine along with battery and ignition fuses are fine.
Completely stumped. I’m assuming the RJ cable shorted out? Not sure how.. anyone had something like this happen? Seems no power from”ignition sense” where there is indeed power.
HappyDogK9Unit
