The entire Responder LP mini lightbar, which has 6 CON3 modules, only uses an average of 1.2 amps and has a peak load of 3.0 amps , so one individual CON3 module would normally use 0.2 amp. It would take 5 of them to use 1 amp.
Quote"
The Whelen Responder LP CON3 Super-LED Mini Lightbar provides all the high performance LED warning and signaling benefits in a smaller size that fits all your special applications. Super-LED modules in a rugged polycarbonate base are built to take the roughest conditions and long hours you face. They're road tested, vibration and moisture resistant and use much lower current than other warning lights. Put a Responder LP to work on your utility, security, fleet, construction or public works vehicle.
Features:
100,000 hour rated life.
6 Super-LED, conical (CON3) modules.
Built-in electronic flasher with 30 Scan-Lock flash patterns plus 4 simulated rotating patterns.
Action-Scan is the default flash pattern.
Permanent mount includes 6" pigtail.
Polycarbonate dome with smooth exterior will not gather dirt and dust.
Class 1, SAE J845 Certified.
Voltage: 12 VDC
Current: 3.0 amp draw (peak), 1.2 amp draw (avg)"
end quote
