Fenn
I have a older ARJENT SL. I'm trying to get to mode 2 and also get the flashing takedowns to work. I have the wiring diagram. I applied power to the wht/blu and wht/yel wires which say its mode 2 on the diagram and the bar doesn't turn on. Hook the mode 1 wires back up and it works fine. I hooked all 4 wires, mode 1 front and back and mode 2 front and back, together and still it's on the same pattern. From what I read the factory programmed a seep rate pattern for mode 1 and mode 2.
As far as the flashing takedowns, if I just apply power to the wht/red they did not turn on. Does a mode have to be turned on at the same time for it to work?
I've gone through this install manual and can't find anything regarding this. I appreciate any help.
