Attention Radio Techs! Please help identify...
tiki_dood
51
Seattle, WA
Okay, I just picked up my latest restoration project from the state of Washington. It's a 1990 Caprice 9C1 that belonged to corrections it's entire career. I am hoping someone can tell me what kind of radio this had in it based on the "brain" mount in the trunk and the plugs. Take a look, any input would be helpful:
In the car:
In the trunk:
Reminds me of a Syntor or Micor setup.
Could be a high power spectra too.
Respondcode3 said:
Nope different mounting tray and the spectra has a DB25 end on the cable the only thing the same is the head and speaker bracket
Yeah, my bad wrong connector... I knew I recognized that connector from a spectra, but it's to connect a sys9000 siren amp... :oops:
Yes, Motorola Syntor, probably to a Syntor XX or 9000 control head. You do not want to cut the cable, since you would need to replace the entire wiring harness. That rectangular connector made installation a real kick in the a**.
I still have keys to the trunk slide out tray somewhere, but we haven't used any of these in about twelve years.
tiki_dood said:
Is that of the correct vintage for a '90?
Also, what's the key for?
Technically, yes. Specific for that actual car/dept use, not sure.
The key was to lock down the radio to the trunk tray (or something of the sort) Dunno why thou, its as heavy as a boat anchor- you would need a forklift to move it! :lol:
Oh, and
DO NOT buy that radio, its WAY overpriced, IMO. Best to ask over at batlabs, guys there have "rooms" full of these bad boys. :twisted:
If you ever "ham" it up around 10 and 6 meters (30mhz to 50mhz) you would do yourself a favor by picking one of those up in that band. Apparently they are worth their weight in gold on the low band stuff. Very very stable from what I hear, and able to handle the "large" frequency split- without any magical blue smoke. ;) http://en.wikipedia.org/wiki/Magic_smoke
More info can be found here.
http://www.batlabs.com/x9000.html
http://batboard.batlabs.com/viewtopic.php?f=1&t=89295
Bottom line- if you can RX or TX low band in your area- find one!
(IMO, this is still expensive... but this is what I am talking about: http://cgi.ebay.com/MOTOROLA-SYNTOR-XX9 ... 439fb1853f )
gabyluis_1
