"BEEHIVE" / "JELLYJAR" Light Thread
rick h.
Veteran Member
As always a beautiful collection .the #14 pic of the one red flasher unit with the extra blue lense looks like one I have in my collection
OP
OP
dmathieu
dmathieu
Premium Member
Below are Federal's versions of the "Beehive" light.
Federal called them "Scatter Ray", later renamed "Scat-O-Ray" lights
Federal Enterprises BR-2
Federal Sign And Signal BR-1 portable, meant to be mounted on a 6 Volt battery. (This is actually a Carpenter Light, but Federal's was almost identical)
Federal Sign And Signal BR-2, newer design
Federal Sign And Signal BR-2S
Federal Signal BR-2S H, 55 Watt halogen version.
STATEY183
I WANT THEM..................ALL!!!! Great collection Dan!!!!!
Skip Goulet
Passed Away
Dan: Is that one light with the plug-in built by 'Lectric-Lites? I recently made a deal for one via this board. They were built in Ft. Worth, and I knew the company owners at one time. I have one NOS and two used red Federal BR-2s. I'd like to find a blue lens for one.
OP
OP
dmathieu
dmathieu
Premium Member
The light with the red cord and plug is a K-D Dash Flasher.
The one with the metal base, and black cord and plug is a North American.
Crownfire
That Griffin 360 is beautiful with the amber dome. The lenses with horizontal only optics are hard to come by. Most that you see have both horizontal and vertical ribs.
OP
OP
dmathieu
dmathieu
Premium Member
These also seem to give out a brighter more intense light than the double fluted variety. .
ex416
congrats on the new addition Dan. that's a cool looking light. you sure do come up with some nice lights
Skip Goulet
Passed Away
That's only because Dan sits at his computer 24/7 looking for this stuff. Nobody can beat that way. :yes:
toon80
Veteran Member
He doesn't even needs to sleep.
J/K Dan :)
OP
OP
dmathieu
dmathieu
Premium Member
kitn1mcc said:
maxi signal is still in business did they the rebadge tomars stuff
Looks to me, like Tomar products rebadged for Maxi.
The tag / badge actually says mfg. by Tomar.
OP
OP
dmathieu
dmathieu
Premium Member
Skip Goulet said:
Dan: This set shows the two different bases that Federal used on the BR series. Do you know when they switched from the flat base to the rounded base?
Sure Skip.
The older BR2, and the newer BR2 bases were meant for watertight flat mounting, like on the roof.
The Higher base BR2S, and BR2SH , according to Federal, were specially designed for rear posting on fire trucks.
Skip Goulet
Passed Away
dmathieu said:
Sure Skip.
That's interesting, as I've seen both styles mounted both ways.
OP
OP
dmathieu
dmathieu
Premium Member
With the BR2S model, there is no gasket to seal the wire hole in the roof against water infiltration. You would have to seal it with putty or silicone, not really the proper way to do things.
Skip Goulet
Passed Away
I have two with that rounded base and three-bolt mount. Both came with small grommets to seal the wire. Since I haven't mounted them anywhere, I don't know how well the grommets work.
OP
OP
dmathieu
dmathieu
Premium Member
Here's a new one added to my "Beehive" - "Jellyjar" subcollection.
Model # not marked.
Online statistics
Members online
8
Guests online
61
Total visitors
69
Forum statistics
Bryanlodes
Top Bottom
