Best Inexpensive Lightheads
I have a non-warning, non-emergency project that needs some reasonably high output lights. I’m currently using SOS Led3 minis but want something brighter.
I was leaning towards the Feniex Fusion as they run about $50/head. The lights may get some occasional rain but exposure but they’ll be stationary so wind won’t be pushing water in.
Is there anything at a better price point I should be considering?
Sparky_911
Gold Supporter
What type of project? Look into superbrightleds.com. I've bought everything from bulbs to heads to parts from them and no disappointments yet.
OP
OP
J
John Hearne
A range prop. A wireless remote controlled light that has three LEDs on it. The lights can be activated in any desired combination as a shoot/no-shoot indicator. It’s actually a set so I need six heads.
And thanks for the tip. Those $25/head lights look perfect assuming they’ll steady burn
FEVER
Platinum Supporter
The feniex t3 is probably the cheapest quality light you will find that will steady burn. $29 each plus our standard site discount takes almost $3 off of them.
OP
OP
J
John Hearne
I dug into the manual and this model has a steady burn mode:
EMT-BLS
They call it a "18 watt" light...so they obviously have no idea what the hell they're talking about.
Sparky_911
Gold Supporter
6leds x 3w per led =18w.
HOWEVER...when it comes to LEDs lumens mean more than watts. Given the project being referred to here I'd say those would work just fine.
Would I put those on my POV or dept truck, prolly not. I'd have to test them out real life first.
EMT-BLS
It's bullcrap. First off, even if the LED is actually 3 watt (which most are not), they aren't run at full power. Second, the wattage of a light isn't calculated by adding up the combined wattage of each LED. It uses 3 watt LEDs, so it's a 3 watt light. It's a marketing ploy to just starting adding up random figures.
Online statistics
Members online
9
Guests online
199
Total visitors
208
Forum statistics
SuzanneBeMe
Top Bottom
