I have also used the Tremco product.
Tremco is easier to install, but I don't like that a key is left in the ignition that could be taken. The Able 2 Ignition override does require a button to be pushed before removing key. The brake pedal will disengage override rendering the vehicle simply parked in the event someone tried to drive it. If the key is inserted and turned to the "run" position, the car will drive normally when the brake pedal is pushed.
