Bloomin' Onion BR skirt--why?
Every few years one of these is posted with the skirt completely sliced up and each time I wonder what the motivation was to do so:
1. Extra ventilation?
2. Ensure that it fits any roof angle?
3. Verify the new tin snips are sharp?
4. Ensure that no one steals it?
5. Some kind of artistic statement?
I'm not the sharpest tool in the shed as there's probably some simple explanation, but dang if I can find it...
I'd venture that is correct. Brass is malleable, but also very brittle. Temp changes and the chrome coating probably doesn't help over the long term. Heating up and cooling down over the years.. basic physics primer 101..
The manufacturing of the skirts uses a technique called metal spinning. It’s a quick and easy (cost effective) way to make the skirts instead of stamping or pressing them. One of the drawbacks is that spinning can create fractures in the brass that can lead to cracks over time.
Reactions: stansdds
As Maxim2Eng mentioned, they are not stamped brass skirts, but spun brass. Micro-fractures are formed, then propagate over time with vibration, heating, and cooling cycles. Dropping the skirt on a hard surface likely does not help either and that can happen during installation and bulb or dome changes.
Reactions: Maxim2Eng
gotcy712000
