California Beacon question
1968
97
CT
I think there was, though I could be wrong a California compliant variant of a Federal model 17 that had a clear dome and had the front sealed beam in steady burn red mode and the rear in the blinking amber mode. I'm I just crazy or did this model exist? I thought I saw an image of one online a year or two ago.
TDC
Dec 4, 2012
175
Carswell AFB, TX
The Red and Amber, yes .... a Clear dome would not be California compliant, based on the age, because there was no White flashing warning light forever, until recently, like the CHP Vision era.
Watch the end of Once Upon a Time in Hollywood and note the red and white beacon on the top of the ambulance, which is wrong for the time.
A similar version appears in Bullitt, in San Mateo or wherever he finds the girlfriend, with a Red 17 and Red to the front mounted on the base.
1968
97
CT
CT-1 is the lightbar assembly complete. I never saw the single offered as a catalog item.
I did mean the CT-1 lightbar when I stated California spec. I should have been more specific to what I was referring to. My question should have been in reference to "Mid 1960s" are you referring to the visibar series of lightbars entirely or specifically the model CT-1?
CD3
411
USA, CA
The San Mateo Co. Sheriff's office ran the FS Mod. 17 with a steady red and a flashing amber rear, the beacon was a red dome. when they turned on the rotating light the amber turned off. They used these from the early 60's up to 1972 when they and most agencies moved to the CA. Twinsonic. NOW a little tid-bit The sheriffs beacons had "RUBBER 4001 bulb holders" rear and front housings, YES RUBBER ! I had one given to me in 1976. I sold it in 2001 for, well I couldn't turn down the offer. The Rubber housing could be removed by pulling in an angle upward it would come off of this 2 1/2" like metal washer that was bolted to the beacons housing you can easily remove the 4001R or 4001A bulbs and with a little water and soap push them right back on. When they were in place they were pretty solid. It was very unique to say the least.
Reactions: dmathieu
1968
97
CT
Are there any images of one of these units out there?
CD3
411
USA, CA
So far this is the best I can find, taken by my father in the 70's when he was a officer. I may have one person that just might have better photo's. When I spoke to him he remembered SMCO SO running those and he too brought up the rubber housings but they did have some with the metal PAR 46 housings too.
Reactions: JohnMarcson
1968
97
CT
Looks like a '69 Plymouth. Was the siren electronic or electro-mechanical?
CD3
411
USA, CA
electro-mechanical which they ran until 1971-72
Here is a couple more pic's, San Carlos and Menlo Park PD's ran them as will, also a 1960's picture from by buddy San Mateo Co S.O. on traffic stop
ErikH
