Carbide Working with Soundoff M Power And Other Questions
movi3king
111
New York
Hi hope all is well. I was wondering if anyone knew if A Whelen Carbide will work with Soundoff M Power Lights.
My application is a Tricolor M Power that i would like steady burn across all colors as well as warning combinations.
I also was wondering if other LED's that are not neccessarily warning equipment would require an external flasher or if the Carbide can flash those LED's as well. Lights i am referring to are Rigid Industries D2 Driving Lights that i do use on steady burn but would like an option to flash. Rigid Industries does sell a flasher for these lights, i was wondering if it would be needed.
Thats all my questions for now.
Thank you in advance for all your responses!
Cheers!
coopers
271
WA
Cheers!
If I remember correctly SOS lights will not work with Whelen Carbide...I thought I had seen otherwise but when I asked I was told no.
jmarino
1
Lunenburg, Mass.
Cheers!
Just ground the green wires. Set the pattern to steady, and you will be able to set any pattern with the carbide
