CenCom Gold problem/question
RickLBZ
184
Miami, Fl.
I was recently attempting to change the settings on a unit. I extracted the original setting, saved them, opened a file I already used and transferred it. Now when the slide switch is activated it doesn't cancel when turned to the off position, i.e. go from off to 1 then off, it stays on 1. If you go back to 1 then to off, it turns off. This applies to all 3 positions. Being confused I transfered back the original file and this still happened. I then opened a new file, selected the setting of my choice, transferred it and it solved the issue.
Anyone ever experience this or know the reason for the problem?
SpartanBL
