CenCom Gold question
KCOEM9103
60
0
44
Elgin, IL USA
Quick question for you guys. I run a rear Inner Edge in my car controlled though my CenCom Gold. I have it set to "single button, 2 wire TA" to control the arrow and warning patterns of the bar. When programming the unit, under the flash button, there is a box labeled "Enable TA Display" I have it checked. Is that supposed to put the TA display on the control head into a flash mode when the flash button is on?
The TA display works fine when I have it in left, center or right. It displays a left, center or right sequence (it doesn't match the pattern I chose on the inner edge, but it tells me the direction at least.) But when I have it in flash mode, It doesn't show me anything on the control head.
Any thoughts?
TNConstable
