amccullers
On a cencom it says fuse the 2 8ga wires at 50 amps each,how are ya'll doing this? Do you use a block like this Stinger SPD5625 Four Position Fused Distribution Block Car Audio - SPD5625.
A fuse block will be on another fuse also.
I bought a cencom red without any wires. I think I found the anderson connectors I need. Tell me if I'm wrong.
10 ft. 8 gauge Power Supply Cable with 75 amp Powerpoles [PSC-08] - $18.99 This would be for the power comming in and but another one for the 40 amp outlet.
Powerpole to Bare End Adapter [PP-2-Bare] - $6.99 I would get 2 of these for the 2 20amp outlets and system power
If anyone has the pieces to add the TA function or other wires let me know.
Thanks
Andrew
Thanks
Andrew
