They are not the same as a duplex edge, they only share the halogen assembly
Best pic I have right now, there is what the duplex setups look like. the filter screws over the light to the base mountsI appreciate being corrected!
Are they prehaps the same filters used on a DashKing?They are not the same as a duplex edge, they only share the halogen assembly
I always like to look for the factory parts first but yes, that's an option. Probably a risky one trying not to crack the lens as I cut it to size.They are not the same as a duplex edge, they only share the halogen assembly
Centurion parts are somewhat on the rare side, but there looks to be enough room that you can take a section of amber edge lens and cut it down to fit in as a filter instead of trying to find the whole assembly
I have new and used lens sections and can cut to size if you can give good measurements
for used sections yes they can be easily cracked, as for new pieces they can take quite the beating and not be damagedI always like to look for the factory parts first but yes, that's an option. Probably a risky one trying not to crack the lens as I cut it to size.
